Hello guys i have a door sensor and the battery is low
the battery already installed is 1/2AA 3.6 V. I am unable to find any 1 around here ![]()
Can i install the CR2 battery (3 V)? it is available with good prices also
Thank you
Thank you
Would a CR2 actually fit? It is about 3mm longer than a 1/2AA and also about 1mm wider. If it did fit it would probably work initially but show low-battery quite soon due to the lower voltage. It may do as an emergency measure whilst you procure the correct battery.
Anyone in the middle east can tell me where can i find such batteries ![]()
