Door Lock Pin Code Setter App?
I’ve got 3 quickset and one schlage lock with a common list of 10 pin codes. I’d like to quickly clear and upload a new set of codes to all the locks with one app. Any thoughts?
Also interested, but I thinking its not gonna work. I also have notifications set in each one for each code.
There are several discussion on this. See the following:
Synchronizing pin codes
Syncing Door Lock Pin codes from Web server on the fly
There is no app that will allow you to sync the pin codes. You will have to create your own solution.
  • Garrett
