I am not able to get the app to wake up in the sense off turning on the tablet if the screen was off. For those interested, here is how you can accomplish this using other means:
Apps/Plugins:
[ol] [li]Vera
[list type=decimal]
[li]Install the ImperiHome Vera plugin[/li]
[li]Install the VeraAlerts Vera plugin[/li]
[/list][/li]
[li]Android Tablets/Phones
[list type=decimal]
[li]Install Imperihome on any tablets you want to be activated by the doorbell[/li]
[li]Install VeraAlerts on the same tablets[/li]
[li]Install Tasker (paid) on those tablets[/li]
[li]Install Secure Settings Tasker plugin (free version works for this)[/li]
[/list][/li]
[/ol]
Vera Setup:
You can use scenes if you want, or PLEG. a scene is probably the easiest. I’m not going to go into too much detail for any given step (ie. setting up veraAlerts)
[ol] [li]Initial Setup
[list type=decimal]
[li]Link ImperiHome plugin to your tablets/phones (You will need one vera device per tablet/phone).[/li]
[li]Set up VeraAlerts for each tablet/phone (I used Lan alerts instead of google because they are faster)[/li]
[/list][/li]
[li]Set up a scene
[list type=decimal]
[li]Go to the advanced tab[/li]
[li]Select the VeraAlerts device and then the “sendAlert” method. Tell it the message (In my tests I used “wake”) and the recipient (I used my master bedroom one ‘master_bedroom_lan’ as I set it up in VeraAlerts).[/li]
[li]Select the Imperihome device and then select the “GotoDashPage” method and tell it the page number (they start at 0, not 1!) (I actually set this part of the scene at 2 seconds to make sure ImperiHome was open. I don’t know if this was necessary)[/li]
[li]You will have to do b and c for each of your devices that you want to activate. For b, you could create a vera user and link all your devices to that user and just do b once and enter the user (for instance I have SirMeiliHouseNotifications) (For c, it would be nice if the Imperihome Plugin allowed you to set up more than 1 tablet/phone per device like VeraAlerts does, but Oh well)[/li]
[/list][/li]
[li]Setup Tasker
[list type=decimal]
[li]Create a profile based on Application → ImperiHome
[list type=decimal]
[li]Create a task (I called mine ‘imperihome running’) and use it to create an action for variables → variable set and set %imperihomeRunning = 1.[/li]
[li]Create an exit task (I called mine ‘imperihome not running’) (create an exit task by long pressing on the first task you created on the profiles page and it will give you and option to create an exit task) and use it to create an action for variables → variable set and set %imperihomeRunning = 0[/li]
[/list]
[/li]
[li]Create a profile based on Event → UI → Notification and choose “VeraAlerts” as the owner application
[list type=decimal]
[li]Create a task (I called mine ‘Wake up’).[/li]
[li]add an action Plugin → Secure Settings for ‘Wake Device’ ( set a duration of 10 seconds, but it doesn’t seem to have any affect on my tablet) (use the Configure line at the top and it will open secure settings and give you the options. make sure to click “save” in secure settings)[/li]
[li]Add an action App → Load app and choose ImperiHome. check the ‘if’ box and put %imperihomeRunning for the variable (keep the middle part ~) and put the value as 0. This will make it so it only opens imperiHome when it’s not the active app.[/li]
[/list]
[/li]
[/list]
Now, if you want, you can set a trigger on your scene, or use PLEG to activate the scene when the door bell is pressed. You can also have the imperiHome vera plugin send TTS to every tablet to say “Someone is at the Front door”. I’m sure there another options (such as using the Sonos plugin, or using a home brew setup for a “chime”). I’m also not sure how Imperihome handles video feeds (I don’t have any cameras yet). If they start automatically, then there you go. If not, maybe they can add another call in the API to start a feed from Vera.
I hope it’s not confusing. I just got back into tasker just so I could do similar tasks (turn on a tablet and go to a certain page when a light is first turned off in a room, say the bathroom). Tasker has changed alot since it first came out (when I was using it), but I think I summed it up pretty quick. There’s lots of information about tasker on the net, but I’ll answer any questions that I can.
Also let me say that I’m not trying to take away from the ImperiHome team. I’m hopeful that most of this will eventually all be able to be done within Imperihome itself (via the Android app and the Vera Plugin), but at this time I just couldn’t get it to do exactly what I wanted. For instance, the camera wake feature doesn’t turn the screen off, so I use Tasker and Motion Detector to accomplish the same goal.[/ol]
