Dont find serial device
Hi!
I have trouble using a RFXtrx433.
I get “RFXtrx controller device[6] : Failed to open IO Port” in UI7.
The serial port shows up Develop Apps / Serial Port configuration and the /dev/ttyUSB0 file is created fine.
However, the ser2net process is not running and I find this in LuaUPnP.log:
[tt]10 06/20/15 0:39:36.145 XXX-UpdateSystemMessagesTasks now 1=RFXtrx controller device[6]: Opening IO Port timeout 0 (-1434753576) count: 2pend:Opening IO Port/err:(null)/done:(null) <0x77847520>
10 06/20/15 0:39:36.146 UserData::m_iDataVersion_Variables_incr short sys message user data 753555001 variables 753555045 <0x77847520>
31 06/20/15 0:39:36.146 AlarmManager::Run finish callback for alarm 0xde6e00 entry 0xe02560 type 24 id 46 param=(nil) entry->when: 1434753576 time: 1434753576 tnum: 1 slow 0 duration 0 <0x77847520>
35 06/20/15 0:39:36.147 PIDLOG 13610 start ThreadedClassThread <0x76447520>
32 06/20/15 0:39:36.147 ThreadedClassThread::ThreadedClassThread running internal run ptr 0xe02a90 <0x76447520>
32 06/20/15 0:39:36.147 ThreadedClass::InternalRun <0x76447520>
35 06/20/15 0:39:36.148 IOPort::Run starting for 6 <0x76447520>
25 06/20/15 0:39:36.148 IOPort::Connect device 6 connecting to 127.0.0.1:3481 iodevice: 8 path /dev/ttyUSB0 <0x76447520>
25 06/20/15 0:39:36.149 IOPort::Connect connect 1: 127.0.0.1:3481 <0x76447520>
01 06/20/15 0:39:36.150 IOPort::Connect connect -1 127.0.0.1:3481 <0x76447520>[/tt]
Any hints?
// Peter
