Dongle with Vera 2 and Ui4
I recently purchased and installed the Vera 2 and it came with UI4 but it did not come with a dongle. I just bought an Aeon Labs DSA02203-ZWUS - Z-Stick USB Adapter (Series 2) dongle and tried to use it to install some new devices so i dont have to cary the Vera2 around but i cant get it to work. I can add the devices to the dongle but when i insert it into the Vera2 nothing happens. Any suggestions?
Homeseer would be my 1st suggestion.
My 2nd would be to change the port assignment from the internal chip to the dongle.
JOD.
Are you suggesting replace the Vera 2 with Homeseer? How do i change the prot assignment?
http://forum.micasaverde.com/index.php?topic=4761.msg26069#msg26069
JOD.
JOD, One more question. If i do switch the port do all the devices have to be on the dongle or can some remain on the chip and some be on the dongle? Right now i have about 20 devices on Vera 2.
Thanks for the help!
Do a backup of your current system. Go to Z-wave device. Advanced. Back up Dongle.
Then do a backup system. Advanced. Backup.
When thats done and you have saved the file to your PC.
Change the port.
Now put the dongle in the appropriate usb slot.
Restore your backup that you just saved.
You should now be running from the Aeon dongle.
None of the information will be deleted from the built in chip but you wont be able to use both the built in & usb devices at the same time.
JOD.
Ill give that a try. Thanks so much!
