Dongle Issues - Flashing Dongle
I’m in the process of setting up my second Vera and experiencing something I haven’t seen before.
When I unplug the dongle to add the Schlage Lamp Module (RP200) to my system the Dongle continues to flash slowly (like include mode). I pressed the button once, as I had read you should do to turn the Dongle off, but it continues to flash slowly.
After much reading I discovered the reset button on the Dongle, I followed the instructions and pressed the reset button with a paperclip for 5 seconds. When I released the reset button the Dongle flashed twice slowly and then started to flash quickly (like in the remove device mode). If I plug the Dongle in to the Vera, it will return to it’s regular slow flash mode. When I remove the dongle again, it continues to flash and pressing the button won’t turn the Dongle off.
If I reset the Dongle again it returns to the fast flashing mode.
I’m looking for anything I might have missed here. Suggestions?
Currently working:
Dimmer (was added with the dongle)
Linksys WVC54GCA
Schlage LiNK lever
Currently not working:
Schlage Light Module (RP200) (but was working with Schlage LiNK service and was removed before I unplugged my Schlage bridge)
I’ve replied to you by email.
