Does Remote Access Currently work for UI4?
As I look through the forum I see some concerns about remote (i.e., WAN) access to Vera for release 1.1.1047. A number of posts refer to the inability to access Vera remotely across the WAN (see attachment). The following references are to the various forum posts. There are more.
 http://forum.micasaverde.com/index.php?topic=5101.msg29518#msg29518:
 http://forum.micasaverde.com/index.php?topic=5162.0
 http://forum.micasaverde.com/index.php?topic=1570.0
I would like to see how pervasive these problems with remote access are. If you can currently access your Vera remotely through a WAN connection, please select Option 1 for your vote. If you cannot access Vera remotely respond to option 2 in the vote, etc.
Voting closes within 30 days. You will be able to change your vote as your access to Vera changes.
Remember, this survey is only for those individuals running release 1.1.1047 and accessing Vera remotely (or a combination of local and remote accesses). Thanks.
                 Jack
