Does Linear make a standard on/off 3-way switch?
As stated. I got in on the 4 pack slickdeals 2-way Linear switches and need a 3-way to control the slave of a multi-switch lighting circuit. However, I am only able to find Linear 3-way DIMMER switches. I just need an on/off switch. Am I missing something?
Please see here: http://www.linearcorp.com/product_detail.php?productId=1580
The WT00Z-1 should be able to control your devices. It’s a scene controller. I’ve used it to control other devices, but not your specific On/off switch.
With newer zwave switches, think in terms of load controllers and scene controllers. You purchased four load controllers. You could put in a WT00Z-1 or even a Enerwave scene controller that can do more in the three way location. Redoing traditional multiway circuits is an opportunity to add functionality beyond making the circuits zwave switchable.
