Is there any hand held remote that will ACTUALLY WORK to control vera3 scenes?
That means the buttons on the remote that are intended to activate and de-activate a scene actually do what they are intended to do on the remote?
Every post I have seen on the Ge/Intermatic … all sound like they don’t work (i.e. buttons turn scenes on but not off, buttons activate the wrong scenes etc.).
Sounds like you are in the US?
In Europe, the Aotec MiniMote hand controllers (4 buttons) work exceptionally well, with a very nice configuration interface in UI5. Not sure if these are available over there?
The mini mote is available - but I have not seen any details on exactly what it will do.
In other words is it possible to use one button to turn scene 1 on and off with the same button?; button 2 scene 2 etc? - in other words just like it would work if Vera (U15) were not involved?
I have each of the four buttons programmed to toggle individual lights… One press ON… One press OFF. Also, a LONG press on each button gives you access to another four possibilities. My choice, in fact, is to make a long press on any button turn off the whole group… Very easy to use.
Thanks for the info.
I will order a minimote.
How are you “toggling” lights - are you using PLG?
If so what does the condition look like?
[quote=“Chelseagroup, post:5, topic:178674”]How are you “toggling” lights - are you using PLG?
If so what does the condition look like?[/quote]
Toggle state is a standard option under the ‘advanced’ scene tag for most switches.
I’m not a PLEG user.
Hello, My name is Mike, I live in Stockholm, Sweden, I own a Vera 3 (UI6), 10 x Fibaro Wall pluggs, 9 x FGD211, 3 x FGS211, 2x FGS221, 4 x Aeon 4in1 multisensors, 3 x wall controllers, and 1 x AEON 4 button key fob.
I cannot make my key fob to work, no matter what i do.
I reset the key fob by pressing the MODE button on the backside for 10 seconds until it flashes green and red. After that i paired the key fob with the Vera 3 by following these instructions: http://support.micasaverde.com/customer/portal/articles/1150720--aeon-labs-pairing-the-key-fob-controller
Vera 3 finds it as a scene controller. I create a scene by following these instructions:http://www.vesternet.com/resources/application-notes/apnt-22
I can now see in Vera–>Devices–>Key Fob–> that button 1 is assigned to my scene.
If i run the scene it will work flawlessly. If i press button 1 it will flash red. I tried to change mode by shortly pressing the MODE button then by pressing button 1 it will flash green. Once again nothing happens, no scene is activated.
Does this have anything to do with UI6, or did i miss something?
Thank you in advance,
/Mike
Does the Vera log show anything when you press the remote button?
Can you manually set up a trigger (rather than configure the remote) to run the scene when the key is pressed?
Hi akbooer and thank you for replying,
Nothing happens in Vera when i press the keyfob’s button.
I created a scene that turns a lamp on, then i klicked on the “trigger” menu under automation and created a trigger by choosing the keyfob–>a scene is activated–> gave it a name and chose button 2 for scene number–>Confirm changes–>Save.
“Can you manually set up a trigger (rather than configure the remote) to run the scene when the key is pressed?”
I’m not sure I understand what you mean by that… Other trigger than the keyfob’s button?
Thx,
/Mike
Here are a couple of pictures illustrating how I set it up:
Thx,
I will try to describe as accurate as possible the way the key fob behaves:
If I press button 1 it flashes green for about 30 seconds or so. Nothing happens.
If I press button 2 it flashes red for 30 seconds. Nothing happens.
If I press button 3 nothing happens.
If I press button 4 it will flash green for 30 seconds. Nothing happens.
This doesn’t look right to me so i try changing mode by pressing shortly on the MODE button on the backside. After i do that when i press one of the 4 buttons it will briefly flash red.
I must be doing something wrong. The manual says: when in USE-mode pressing one of the 4 buttons makes it flash green for a few seconds only, not 30 seconds.
I attach pictures of my setup:
From memory, and on UI5, once included and switched to the operational mode, pressing a button would give a brief green flash on the LED. This was working out-of-the-box (i.e. without changing anything in Vera / presumably a newer keyfob).
Sorry @mickesanda,
I just realized that the parameter values I posted were from my ZWave.Me Keyfob. I no longer have the Aeon one (gave it to a friend with an HC2).
I would try excluding and re-including your keyfob. Also see if this helps: Vesternet APNT-22.
No worries mate, thx for wanting to help, i’ll keep you posted
I got it working, I failed to read closely the manual
