Documentation for the HTTP interface
Hi, I am a new owner of the Vera Edge controller, and I can’t find documentation for the HTTP interface anywhere. I simply want to put a URL into my browser and get back, say, the current temperature on my thermostat. For example, I use the URL “http://192.168.0.104:3480/data_request?id=lu_action&serviceId=urn:upnp-org:serviceId:TemperatureSensor1” and I get back an error saying “No service/action”.
I presume I need to add a token like “&action=xxxxx”, but I can’t find any documentation on this. I’d eventually like to control the heat and cool setpoints, and retrieve current setpoints and current temperature.
Can someone point me in the right direction?
Thanks in advance for your help.
http://wiki.micasaverde.com/index.php/Luup_UPnP_Variables_and_Actions
Thanks for the quick reply, but this page doesn’t provide the basic structure for HTTP requests; it only provides a long list of variable names and actions (assuming you know already the structure of the HTTP requests). There are a few examples of HTTP requests on the page, but they don’t provide all of the structure; only a very small part, I suspect.
I found one post that mentions, in passing, the use of ‘lu_variableget’ and ‘lu_variableset’, an something about an invoke command. but I assume there is a central place which lays out the HTTP GET framework for interfacing with the Vera. Can anyone point me to it?
Thanks.
This should give you a fair amount of information: http://wiki.micasaverde.com/index.php/Luup_Requests
However, it is not exactly complete.
Fantastic, this is exactly what I was looking for, thanks so much.
(Just as an aside, I wonder why it wouldn’t be complete? Is Vera not a well-documented platform? I have to say that in my first few hours I am completely confused - and I have a decade of experience in home automation, scripting, app dev, IP communications, and so on. I guess each platform has it’s own way of doing and saying things. And so I am probably looking at things through the lens of, say, Homeseer, or ISY, which I use extensively).
Anyway, thanks a lot - this will get me where I need to go.
You’re welcome!
How to put this politely? Um…, no, it isn’t.
