Do I want Beta Fimrware 1.5.672?
I have some things not working:
  • Devices uses on trigger on SLAVE Vera Lite Unit, show on bridged MASTER Vera 3 notifications on each reboot (false alarms).
  • Aeon Smart Strip - Can’t monitor the energy on a the per outlet basis. Can only do the combined 6 outlets (which is OK).
  • Tamper Alert for Aeon Door/Windows sensors are not actionable in Vera
  • General instability, typically when 3 remote tablet clients (grasshopper x 2 and AutHomation) start within a few seconds of each other (overloading vera to populate device statuses?)
  • Inability to send multiple Yale locks and unlock at the same time. I need to stagger them apart 40 seconds (taking 2 minutes) and do them one by one. Locks are 3’, 4’ and 7’ from base unit…and it happens if I unlock any 2 or more at the same time (don’t need to do all 3)
One more thing, I have bridged Vera’s…so hoping to have someone say they have done UPNP bridged mode (master/slave) between Vera’s.
Can’t answer the actual question; however, some of the issues were designed to be resolved in dependant of the firmware by addressing incremental releases via the referenced app.
http://apps.mios.com/plugin.php?id=3846
Thanks sir!
For the limited information on the forum, it seems that smoke detectors is the only thing I could find that it helps with.
[quote=“AgileHumor, post:3, topic:181008”]Thanks sir!
For the limited information on the forum, it seems that smoke detectors is the only thing I could find that it helps with.[/quote]
Does this actually enable the full support of the First Alert ZSMOKE/ZCOMBO detectors? I’m on 15…622 right now but I have several First Alert detectors
Just fibaro mentioned in the forums. I think so, since they added the smoke alarm Z-Wave class.
YMMV as I’m unsure.
