Edge/UI7/Latest FW/UK Installation
Can’t seem to find a straight answer - will the Dandfoss Living Connect RA/K work with Vera Edge/UI7? I’m looking to replace my existing dumb TRV’s with intelligent units and appropriate Thermostats, and have acces to 6 of these - is it worth it or are there shortcomings that are overcome by better/other units?
My heating uses a wired thermostat for the boiler control and separate hot water override - I’m only looking to upgrade the heating side at present.
Would I have free range on the thermostat side, or would I have to use a Danfoss unit with these for some reason?
Thanks in advance
Pat
