At this moment I have DM running nicely, only problem is the 2GB stick shows in the plugin as storage with a total space of 11264 (kb). I’m not sure if the kb is correct or that is’s a typo in the plugin and it should be kB. Anyway its way too little space. So I’d like to try another USB stick, to see if it will mount that one properly. I have a config running for a few weeks, is it possible to copy the old USB stick contents to the new one? Will it work? If not, what should I do to copy the config+data?
All the results and config data are stored on the stick, so you can just copy the whole lot over to the new one, as long as the computer that does the copying, understands the file format of the stick. You can identify the format by looking at the “mountType” in the Advanced Tab of the dataMine plugin. Don’t forget to make a back up first.
I’m surprised you have managed to fill up 2GB in a few weeks. Are the other figures correct: “Disk Space Total (kb)” and “Disk Space Used (kb)”? And yes these are kiloBytes, not kilobits, so the Bs should be in uppercase.
Current USB stick was never recognized properly… It never showed 2GB of total space or anything near that.
What is a simple way of making a backup, will the Vera backup include the USB contents?
