DLink DCS-932L
Unable to get this camera to work with vera2 and newest firmware. Tried every url ever mentioned in every forum.
After it says trying to get image it shows a picture of a piece of film but no image.
[quote=“rdc, post:1, topic:169133”]Unable to get this camera to work with vera2 and newest firmware. Tried every url ever mentioned in every forum.
After it says trying to get image it shows a picture of a piece of film but no image.[/quote]
It seems like with this model you have to enable jpeg access in the camera’s interface? I found this in an Amazon review:
“The D-Link can display a single .jpeg snapshot without the managment interface. This feature can be enabled in the camera’s web interface and it tells the address format to use. This is for direct access, not using MyDink.”
Do you see that option in the web interface, and if so, have you enabled it?
Yes I see that option and I have enabled. I can get a still picture from a web page using just the browser but not in vera
Im having the same issue and Im wondering if you have solved it?
I haven’t looked into the issue in detail, I can’t get my Vera communicating with the DCS 932 and get a video stream.
did you ever get this working?
Yes, I did.
What I did was:
Devices → Add Device → I want to add an IP Camera Add → Manually Add → Paste URL of camera (in my case, it was http://192.168.1.204/image/jpeg.cgi ) and then typed username & password (as I require logins) and then clicked Next and I saw the image of the video, which indicates that it’s working.
Good luck!
