DIY help on LVT wiring system choices
Hi there!
I am finishing new construction with around 20 windows that I hardwired them all for low voltage, all the wires go to my control room. I am pretty newbie on this and need some directions on DYI staring from panel selection (enclosure/transformer/relay…) and an interface to the Vera system. I haven’t purchased any motors yet but I would like to ideally have a feedback from the blind position. Any pointers or help would be greatly appreciated.
thanks!
Anyone? ???
[quote=“Fortknux, post:1, topic:175640”]Hi there!
thanks![/quote]
See my post here:
http://forum.micasaverde.com/index.php/topic,4811.msg115645.html#msg115645
When you get enough posts under your belt feel free to PM me with questions, I am busy though so I apologize in advance if there is a delayed response.
Due to the LV wire it sounds like you need the DC1-ZW or DBMZ motor controllers and dumb low voltage motors. Be aware of voltage drop on longer wire runs.
Thanks Shady,
What do you use for power distribution? I was looking at this one but seems to be quite expensive
http://www.ict-power.com/products/display_digital.php?id=1280
http://www.ict-power.com/products/power_distribution/
You might look around the internet, here are some cheap power supplies:
http://www.mpja.com/Meanwell-Power-Supplies/products/506/
If you want the highest efficiency you might try looking at someone like Mouser.com who lists it in their search criteria.
