I’ve recently upgraded from UI5 to UI7; I have a couple of scenes that run the thermostat at a time set and until I had UI5 I could manually disable these scenes in spring and summer, but I couldn’t find the way to do this in UI7, can anyone help?
Refer to the attached screenshot. To deactivate the scene, click the image that is circled in red and it should turn gray. To activate the scene, click the image again and it should turn green.
Refer to the attached screenshot. To deactivate the scene, click the image that is circled in red and it should turn gray. To activate the scene, click the image again and it should turn green.[/quote]
Wow! All this time and I never spotted that. Very usefull.
Big Karma for you, thanks!
