Disable sensor notifications
How do you disable notifications for 3 in 1 sensors and Door/Window sensors? I tried to look at at the notifications settings for each sensor and there is nothing added, nor something to tell me to disable the notifications. This is very annoying as I never added them. Do they just automatically come with notifications enabled?
If you add the sensor to a scene … there is an option to add the notification there … So you may have missed it.
Go to the Automation Page … do NOT select a scene … select the Notifications tab … look at possible triggers for that device … Click on the Wrench to verify you have not turned a notification on as part of a scene trigger.
