Dimmer Turning On By Itself
Need some advice. I removed the Vera from being a culprit by unplugging it. The light keeps turning on by itself. Throwing the breaker and checking the wiring for loose connections didn’t seem to help. Is the switch bad? Is there a wiring problem? It is a 3 way GE dimmer.
Is this the 45612?
Are you using LED bulbs?
The 45612 passes current even when it is off and this can cause strange behavior with some LEDs. Especially if your total LED load is under 40 watts.
Rather than turning off Vera, you should exclude the switch as the turn on could be coming form some other controller like an associated switch.
If none of the above, then the switch is bad.
No LED bulbs. Worked for several months before this started. So replace the switch?
[quote=“wezley69, post:3, topic:186960”]No LED bulbs. Worked for several months before this started. So replace the switch?[/quote]That, or leave the lights on. It’s up to you.
Nice. I think I’ll have Vera poll the switch each minute then have a TTS message thru Sonos telling my son to get up and turn off the light :stuck_out_tongue:
LOL!
