Dimmable Vertical Fan
I was looking to add a fan to my bedroom. I have an existing unit but it makes weird noises when I dim the Z-Wave module (Aeotec Smart Switch). Also, the fan stays off after the power is cut…so I would need an IR blaster to turn it on.
Instead of an IR blaster, I was thinking of using a cheaper, hard switch (no fancy electronics), vertical fan that can be dimmed.
Are the weird humming noises when I dim the electronic…or can you not dim a fan?
Sorry if this is a basic electrical question. I thought it would work with my existing fan.
Are the weird humming noises when I dim the electronic...or can you not dim a fan?
Most fans use induction motors which cannot be dimmed.
Thanks Rex, using your search terms, I found out more details on why this is a bad idea.
[quote=“RexBeckett, post:2, topic:180227”]
Most fans use induction motors which cannot be dimmed.[/quote]
Well, if someone made a low-cost Z-wave compatible variable frequency drive… :wink:
Would this work?
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=VRF01-1LZ&section=44142&minisite=10251
[quote=“AgileHumor, post:5, topic:180227”]Would this work?
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=VRF01-1LZ&section=44142&minisite=10251[/quote]
The original switch was a 4 position (three speeds and off) switch? This is meant to replace that type of switch.
There may be wiring in the wall for it if you originally has a single pole switch and were using the chain to set the speed.
so the answer is: “it depends” as so many home automation questions tend to get answered.
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=VRF01-1LZ&section=44142&minisite=10251[/quote]If you have a light circuit tied to an outlet that you could replace a traditional switch with, then yes I guess so. Otherwise stick it in a closed dual gang enclosure with a 120v cord and outlet, and hey-presto same thing really :slight_smile:
http://www.homedepot.com/p/Carlon-2-Gang-23-3-4-cu-in-Surface-Mount-Box-5072-WHITE/202077409
Once you mount the fan controler in there, just need to then add an outlet, a dual gang decora face-plate, and way to secure a cord through the side, for which there are few options.
