Dim up/down function Scene
Hi
Is it possible to make a scene that dims the light up or down when i hold a button?
I have the ZRC-90 Scene controller and a Fibaro 2 dimmer. All connected to Vera Plus
At the moment I am able to activate scenes with the scene controller, but I see no function for dim up/down while i press and hold a button.
A
A scene can set a specific dimming level but not work as a standard dimmer.
To do as you wish you need a device which supports association.
Yes if you dive into luup. Wont work on button hold but each press can change the brightness a fixed amount. I took these scenes out because I wasn’t using them and repurposed the remote so this is from old notes; I can’t guarantee it works as is. It SHOULD dim a bulb in 10% increments and if the light is off kick to 100%
local device=40
local mindim=0
local maxdim=100
local switchOnOff = luup.variable_get(“urn:upnp-org:serviceId:SwitchPower1”, “Status”, device)
local lightLevel =luup.variable_get(“urn:upnp-org:serviceId:Dimming1”, “LoadLevelTarget”, device)
  --Switch is on
if (switchOnOff == “1”) then
– Set new brightness target dimmer
lightLevel =lightLevel-10
luup.call_action(“urn:upnp-org:serviceId:Dimming1”, “SetLoadLevelTarget”, {newLoadlevelTarget = lightLevel}, device)
Else
–switch was off
lightLevel =100
End
