dim rate GE 45612
Hi: I would like to change the dim rate GE 45612 so as to make it instant on and off. The manual gives parameters, but not where to change them. I am using Veralite as a controller.
This is from th GE manual:
Dim Rate Adjustments
Both the number of steps (or levels) that the dimmer will change
and the timing of the steps can be modified to suit personal
preferences. The timing of the steps can be adjusted in 10
millisecond intervals.
  1. When Receiving a Z-Wave Dim Command
    ? Parameter 7 (number of steps or levels)
    ? Parameter 8 (timing of the steps)
    ? Length: 1 Byte
    ? Valid Values:
    Parameter 7 (default = 1) Valid Values: 1-99
    Parameter 8 (default = 3) Valid Values: 1-255
    Can someone help me?
    Thank you, Ciro
@ciro307,
Welcome!
There should be some existing topics on this.
It depends on the controller where/how you can set configuration parameters (if possible at all). On Vera, click on the device’s wrench and then go to the [tt]Device Options[/tt] tab. You can use the [tt]Add configuration settings[/tt] button there.
(This might be helpful (screen shot is from the older UI4); this is another thread.)
Hi: Yes, I see that.
Thank you so much!
Just 1 more question.
The manual states the Length at 1 Byte.
Veralite offers 1 dec. byte.
Is that the same?
Please see attached.
Thank you so much.
Ciro
Yep (seems natural to use decimal values for these parameters).
Hi oTi: Once again thank you.
You made my day.
Ciro307
