I have a GE/Jasco dimmer and have a simple scene set up to turn on a light at sunset. What I can’t figure out is how to set the percentage too other than 10% 20%, 30%…I can get down as low as 3% using an app on my phone and would like the scene to do the same.
On the [tt]Advanced[/tt] tab you can set it to ‘any’ value you desire. (Easiest is to set it to say 10% on the other tab, and then override it.)
or with Luup:
luup.call_action(“urn:upnp-org:serviceId:Dimming1”,“SetLoadLevelTarget”,{ newLoadlevelTarget=“3” },10)
replace your device number for the 10
Thank you both, advanced tab worked like a charm.
