Devices showed up out of no where
I just noticed out of no where I have a bunch of motion, doors sensor and a smoke sensor. I don’t have any of these devices on my network. Seems very strange
how do I remove them?
btw: it seems to have came from my HEM?
Do you have an alarm plugin installed? Look at the advanced page and see if they are controlled by an alarm partition.
They’re controlled by the HEM. I haven’t done anything to it in the past couple days
When you reload luup watch the log perhaps an error will appear from the HEM. These kid devices are being persisted from the parent device HEM. In other words every time the HEM runs its startup it thinks it needs these devices. If you delete them and luup reloads then they will come back if you don’t fix the issue related to their creation. If you fix the overriding issue then the kid devices will go away. Depending on how the plugin is written it may actually fix it’s own issues when you reload luup. In UI7 Go to Apps–>Develop Apps–>Serial Port Configuration–>Reload Luup or pick a device, any device, and go to its Advanced tab and click the Reload Engine button on the very bottom of the page.
I don’t use HEM but this is what is going on. I hope it helps.
I’ve seen this happen. Just delete them.
http://forum.micasaverde.com/index.php/topic,27338.msg195433.html#msg195433
Went through and delete almost 20 devices using the command below. What a PITA hope it doesn’t come back
http://<local_Vera_IP>:3480/data_request?id=device&action=delete&device=<device_ID>
