Out of 3 PIR sensors and 3 door sensors on the UI7 Vera, the back door on is the only one that seems to go into disconnected mode on a regular basis. Not sure if it is the sensor or UI7. It’s the Schlage RS100HC same as the other 2.
I had four 4-1 sensors that worked perfectly for a week. Which for Vera seems to be epic (my experience). Then Saturday morning one showed up as disconnected. The rest of my day was spent tweaking, troubleshooting, deleting, re-adding. During the week when everything worked I made no changes to Vera (U17.) The only change has been the request to upgrade every time I log in.
At this point I have set the devices so they are NEVER polled. That seems to help for today…who knows what tomorrow will bring. I have not tried the “luup.set_failure(false)” option.
I was getting disconnects and thought I found solution only to be disappointed when the various tweaks on the board did not work.
For what it is worth, I am at 26 hours and no disconnected device notice for the Aeon 4 in 1 sensor. I set polling to default (leave blank) and went with the default wake interval (1680 seconds).
I realize this doesn’t help everyone but wanted to get it out there since I know how frustrating the disconnected sensor notice is.
