This happens to me a couple times a month. What I do is to reload a past backup file of my system, problem solved. If you don’t have a backup, create a trouble ticket and Vera will remove it for you.
I have removed the devices using the web UI and the URL listed. But they reappear after few minutes. Not sure what is going on. I am running firmware 1.7.2406
@zelam
I had that problem with some cameras reappearing after I deleted them or changed the room it would pop back into no room.
it was the vera app addon plugin that was recreating or reconfiguring the devices automatically.
I removed the plugin and all devices created by it after and started over. all is working now.
hope it helps
