Hi all,
I am newish to z-wave but so far everything has been going well. I have only fitted lighting control so far but i have just hit a snag.
I have a TKB dual paddle switch in the dining room and a single paddle TKB switch in the garage.
The dining room switch controls an outside wall light and the garage switch controls low voltage lighting in the garden.
Doing exactly what i have done elsewhere in the house i then set an association for group 2 (paddle 2) to control the garage switch.
Unfortunately nothing happens. When i look at the neighbours for both switches they do not include each other so it appears that the wall between is blocking the direct signal.
I thought that maybe i can use a virtual switch and a scene so that the dining switch operates a virtual switch which then triggers a scene to turn on the light but group 2 cannot associate with a virtual switch. I cannot just poll the switch because you poll the device you only see the wall light status. I guess group 2 cannot directly control a virtual switch because of the Lutron patent.
So
Can i set up direct routing from the dining room device to the garage device. If so how? I cannot see any variable named manual route. Will itwork if i set up the association with the devices next to each other and then separate them and run a heal. I have done various heals so far but no joy. I think that the heal only heals routes from the controller to devices and not between devices but that’s just a guess.
Any idea’s?
Edit.
Neighbours list from dining room switch (device id 15)
1,2,3,4,6,7,10,11,12,13,14,16,17,19,20,23,24,27,29
Neighbours list from garage switch (device id 33)
1,2,3,6,10,12,13,19,20,21,22,23,24,26,29,30,
Report after heal shows all devices with 5 stars
Edit 2
Have today removed the garage switch and powered it temporarily near the dining room switch and control is fine. As soon as the garage switch is even just inside the garage the link fails. Obviously the brick wall between is the problem. I still cannot understand why routing is not working though. The garage unit has many neighbours in common with the dining switch. Could it be that routing only works on the main switch and not the secondary groups?
