Device missing in scene editor
I’m not sure where this question belongs so…
Anyway, I have a very basic setup with a VeraEdge and a Fibaro Dimmer 2 FGD212. Once I added the dimmer to the Vera Z-Wave network, I noticed that I had two extra “_Dimmable Light” devices there. That’s not a problem as I was able to hide them using the test LUUP code lines.
When I first set up everything, I was able to create some basic scenes using the editor. However, for some strange reason now the main dimmer device doesn’t appear as a selectable device under “Whenever the device…”. The strange thing is that the two ‘ghost’ devices are there and selectable.
I must be missing something but I don’t know what.
Can anyone help?
What you describe is normal. The _Dimmable Light is the device that you should be working with, it is the dimmable load.
Thanks for answering.
It’s really odd because partly due to the length of time it was taking for the post to go live and my impatience I decided to factory reset the Vera Edge and exclude/re-include the dimmer.
Now it’s appearing as it was - I have 1 dimmer light device and 2 ‘ghost’ devices. In the scenes, I can use the ‘proper’ dimmer light device as an event (e.g. When the light turns on).
It hasn’t disappeared yet…
(But now the Energy section has stopped working… )
