Device_file wont comit
Hi all,
Trying to change the device_file value on the advanced tab but when I do and svae changes and do the vera dance. The value returns to the origional value. I seek to change the .xml file to a custom one. I am using a fibaro smoke sensor which I wish to chnage the .xml on to a custom .xml that shows the temp. I can chamge the name of tje file to what is listed in device_file and upload it and it all works, but this effetcs other devices I dont want effected.
Any ideas why changing the value under device_file on advanced tab wont comit?
I am on ui5 on a vera3. I am running the latest beeta formware from mv. I belive it is 1.2.65 but I will check that and report back shortly as not got acess tocjeck vershion number at present.
Any ideas? Its an odd one as on reading around this should not be an issue.
