I was playing with the fibaro universal sensor, I had some issues with it . I reset the device , included it again.
All was fine, but than I clicked the "configure node right now"on the child devices … they stay red and say “device failed to configure” , the “parent” is still fine , and both childs are working as they should , they just show this error message.
Resetting the vera lite didn’t help , pressing the configure now on the parent doesn’t help either.
I don’t think that is something to lol about. It is just stupid from mcv to allow to try to configure child devices, something like this should be prevented by the UI.
However, is there a general solution if you once tried to configure a child device which is now marked read? Cause a heal didn’t help…
I have a child device (Motion Sensor from EZMotion 3in1) which works jsut fine, but it is also marked in red “Device failed to configure”.
Well you know, it isn’t really a big problem since the my sensor is working just fine. And since I only use the vera webinterface to configure and not to control I don’t really care about it. Was just wondering if there is a straight forward solution.
Excluding and including the device sounds simple, but it is used in a hole lot of scenes, and all of these would have to be reconfigured too then. For this reason I don’t like this approach.
EDIT:
I just changed the child devices variable “Configured” from -3 to one, looks better now, error is gone. But I have to check if it still works when I get home.
chixxi ur right its not that lol if you have a dozen devices connected to it and you experience problems with it
i had this error in config before and i deleted the childdevice and press configure on the main device if i remember well.
after setting the Configured parameter in main device to 0 . seems to make the child-device do its job again ok.
probably setting Configured to 0 will do. no need for deleting the child-devices.
think ur right about that one should not be able to reconfigure child-devices . its useless to do that but its nice to have the possibility to set parameters in child-devices. i used this many times on my 2 6-port powernodes.
I’d never accept such a huge risk for such a small error which basically doesn’t matter. Whenever I do things like restoring from backups or updating firmwares and stuff like that I am close to a nervous breakdown, that is how much I trust mcv and their software.
[quote=“chixxi, post:8, topic:176780”]EDIT:
I just changed the child devices variable “Configured” from -3 to one, looks better now, error is gone. But I have to check if it still works when I get home.[/quote]
Did this work?
@ RichardTSchaefer : I am a little bit afraid of restoring a back up as well … especially for such a small issue.
It has been a while ago since I tried this, the error has never reoccured and all child an parent devices work just fine. So for me this is fixed.[/quote]
Hi
I have successfully removed the red error by setting configured to 0 as well. This has worked fine on child devices that have accidently been tried to be configured. I am not sure what this does to the device axactly but it seems to operate fine and doing what it should.
As previously stated it is strange that the UI gives you the oportunity to send configs to child devices. Some might say LOL for even trying that but for people that are new to the system this is not something that comes accross as obvious.
setting it to 0 means the vera thinks its not configured yet and it will configure it as it get the chance or at night with the daily zwave repair.
-1 means it failed at configure device.
1 means it succeeded in configure device
-3 i have no idea
just put it to 0 and save and reload ui and then press configure node now in device settings and it will fix it again to default init
I’m new to this and am having the same error. Can someone teach me how to set the configured variable?
On a side note, I got this when trying to set Fibaro Dimmer parameter 33 (Dimmability of the load) which is supposed to be read only. Surprisingly, it seemed to affect the dimmability state.
In case someone else is searching… I found hit under Devices > (device) > Advanced > Variables
[quote=“sykong, post:18, topic:176780”]I’m new to this and am having the same error. Can someone teach me how to set the configured variable?
On a side note, I got this when trying to set Fibaro Dimmer parameter 33 (Dimmability of the load) which is supposed to be read only. Surprisingly, it seemed to affect the dimmability state.[/quote]
