Hey, I’ve been using the dropdown lists to populate the names so they have the correct curly braces around them, the parenthesis were just my poor explanation sorry! As far as I can see capitalization/spelling is correct, it seems to be failing for all expressions.
Here’s the logic summary:
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.4 config 19226 cdata 19082 ui 19237 pluginDevice 211
System: Vera version 1.7.4453 on Sercomm G450; loadtime 1573635865; systemReady 1573635937; ALTUI v2.45; Lua 5.1; JSON dkjson 1.2
Local time: 2019-11-13T09:31:41+0000; DST=0; Godstone, England United Kingdom
House mode: plugin 1; system 1; tracking on
Sun data: { "stamp": 2019317, "civdawn": 1573627014, "nautdawn": 1573624601, "sunset": 1573661754, "nautdusk": 1573666350, "latitude": 51.2478, "astrodusk": 1573668687, "longitude": -0.06914, "civdusk": 1573663937, "astrodawn": 1573622263, "sunrise": 1573629197 }
Geofence: not running
Heating ON (#243) tripped
Version 19082.38 11/13/19 09:30:59
Message/status: Tripped
Variable/expressions
0: livingroomsetpoint getstate( 139, "urn:upnp-org:serviceId:TemperatureSetpoint1", "CurrentSetpoint" ) [last "19.00"(string)]
1: masterbedsetpoint getstate( 100, "urn:upnp-org:serviceId:TemperatureSetpoint1", "CurrentSetpoint" ) [last "16.00"(string)]
2: maxsetpoint getstate( 232, "urn:upnp-org:serviceId:TemperatureSetpoint1", "CurrentSetpoint" ) [last "18.00"(string)]
3: LRrad5 getstate( 139, "urn:upnp-org:serviceId:TemperatureSetpoint1", "CurrentSetpoint" ) +5 [last 24(number)]
4: MBrad5 getstate( 100, "urn:upnp-org:serviceId:TemperatureSensor1", "CurrentTemperature" ) +5 [last 26.5(number)]
5: MXrad5 getstate( 232, "urn:upnp-org:serviceId:TemperatureSetpoint1", "CurrentSetpoint" ) +5 [last 23(number)]
Condition group "Reactor Sensor 6" (AND) TRUE as of 01:46:08 <root>
&-T-housemode in 1,3 [1 at 14:26:41; T/T as of 14:26:41/14:26:41] <cond0>
&-T-group "Temperatiure Sensors" (OR) TRUE as of 01:46:08 <grpkc40vuv>
| |-F-group "LRbelowtemp" (OR) false as of 08:24:58 <grpkcgyux6>
| | |-F-service Wall Thermostat (139) urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature < {livingroomsetpoint} [19.30 => 19.60 at 09:07:11; F/F as of 08:24:58/08:24:58] <condkc418n5>
| |-F-group "MBbelowtemp" (OR) false as of 07:34:34 <grpkcgz5f7>
| | |-F-service Temperature Sensor (158) urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature < {masterbedsetpoint} [19.37 => 19.31 at 09:30:01; F/F as of 07:34:34/07:34:34] <condkc5mxsh>
| |-T-group "MXbelowtemp" (OR) TRUE as of 01:46:08 <grpkcgz6ye>
| | |-T-service Room Thermostat (232) urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature < {maxsetpoint} [16.47 => 16.41 at 09:27:04; T/T as of 01:46:08/01:46:08] <condkc5o1g5>
Activity grpkcgyux6.true
Device Living Room Radiator (241) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint="{LRrad5}" )
Activity grpkcgz6ye.true
Device Max Radiator (183) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint="{MXrad5}" )
Activity root.true
Device Heating (137) action urn:upnp-org:serviceId:HVAC_UserOperatingMode1/SetModeTarget( NewModeTarget="HeatOn", NewHeatSetpoint="1" )
Activity grpkcgyux6.false
Device Living Room Radiator (241) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint="{livingroomsetpoint}" )
Activity grpkcgz5f7.false
Device Bedroom Radiator (100) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint="{masterbedsetpoint}" )
Activity grpkcgz6ye.false
Device Max Radiator (183) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint="{maxsetpoint}" )
Activity grpkcgz5f7.true
Device Bedroom Radiator (100) action urn:upnp-org:serviceId:TemperatureSetpoint1_Heat/SetCurrentSetpoint( NewCurrentSetpoint="{MBrad5}" )
Events
11/13/19 09:05:32 reload: notice=Luup reload
11/13/19 09:05:32 start:
11/13/19 09:05:33 variable: oldval=28, variable=MBrad5, newval=26.5
11/13/19 09:07:01 devicewatch: device=232, old="16.68", name=Room Thermostat, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="16.51"
11/13/19 09:07:11 devicewatch: device=139, old="19.30", name=Wall Thermostat, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.60"
11/13/19 09:07:51 devicewatch: device=158, old="19.68", name=Temperature Sensor, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.62"
11/13/19 09:12:53 devicewatch: device=158, old="19.62", name=Temperature Sensor, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.56"
11/13/19 09:16:55 devicewatch: device=158, old="19.56", name=Temperature Sensor, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.50"
11/13/19 09:17:03 devicewatch: device=232, old="16.51", name=Room Thermostat, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="16.47"
11/13/19 09:20:58 devicewatch: device=158, old="19.50", name=Temperature Sensor, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.43"
11/13/19 09:27:00 devicewatch: device=158, old="19.43", name=Temperature Sensor, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.37"
11/13/19 09:27:04 devicewatch: device=232, old="16.47", name=Room Thermostat, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="16.41"
11/13/19 09:30:01 devicewatch: device=158, old="19.37", name=Temperature Sensor, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="19.31"
11/13/19 09:30:13 configchange:
11/13/19 09:30:17 configchange:
11/13/19 09:31:00 configchange:
Devices
ZWave (1) urn:schemas-micasaverde-com:device:ZWaveNetwork:1 (19/0); parent 0; plugin -
Temperature Sensor (158) urn:schemas-micasaverde-com:device:TemperatureSensor:1 (17/0); parent 1; plugin -
Wall Thermostat (139) urn:schemas-upnp-org:device:Heater:1 (5/2); parent 1; plugin -
Room Thermostat (232) urn:schemas-upnp-org:device:Heater:1 (5/2); parent 1; plugin -
