The problem I have, I can’t change device parameters under the configuration tab of AltUI v.912.
My Fibaro relay for the hall light is configurated to leave the light on when switched for 10 minutes. My intention was to change the time limit to 20 minutes and I consequently tried to change parameter 4 of the Fibaro from 6000 to 12000 msec., using AltUI.
So far so good, configuration changed, saved and Vera restarted, but the configuration tab in AltUI still showed the old (6000) value. Thereafter I chacked the configuration via Vera UI5 and was surprised to see, the parameter configuration (3 = 1 and 4 = 6000) was completly gone, but still shown in AltUI.
Append are screen shots and debug files before and after the change:
