Device buttons behaving differently in scenes compared to devices themselves
Has anyone seen the buttons for devices when used in scenes behave differently to they way they do when using the actual device ?.
I’ve been programming a venetian blind, after some playing about with settings I’ve finally got the device working well, open to open, close to close and stop to go to “my” position. The device controls will do this all day long as will controlling from imperihome. So programming a scene to open and close blind should be easy.
Create scene to close blind, test all working. Create scene to open blind, just wont work, pressing the “stop” button when running the scene only appears to fire a very short “jog” command instead of the “my” position which pressing stop on the device does. This seems to suggest that the device seen on the devices panel and the one showing when programming a scene are not behaving in the same way. Could be a bug ?.
I know people might shout to use PLEG, I can’t test it as PLEG wont save the device into the action page (comes up blank each time with 0 actions) after save is pressed.
I’ve done a full reboot hoping that would clear things down but its not. Has anyone seen similar?.
