This plugin appeared to install OK, but I can’t get the configuration to “stick”. I check the lights I want controlled, hit “back”, hit “save changes” and the next time I look at configuration, they’re all un-checked… What gives? Anybody else have this problem?
Yes, I experienced the same. I assume you are on UI7 like I am since it was working well under UI5. This app hasn’t been updated for UI7. I got around this problem by manually adding the devices to be controlled via Device>Advanced>New Service. For each device you want to control you have to manually add it. You need to enter three pieces of information. New service (can be found by hovering over an existing variable on the Variables tab), New variable (control0 for the first device, control1 for the second and so on), and New value (the device id) For every device you add you will see a new variable on the Variables tab. Then once you’ve added all the devices, you need to update the countrolCount variable on the Devices>Advanced>Variables tab with the total number of devices you entered. When you go back into the configure tab the devices won’t show as selected but they will be controlled when you Enable the device. It’s a pain but it keeps this app working for me.
A new version of this plug-in has been released and is now available for install.
See this thread: [url=http://forum.micasaverde.com/index.php/topic,54246.0.html]http://forum.micasaverde.com/index.php/topic,54246.0.html[/url]
Edit: updated link to latest “home” for DEMII
