DeusExMachina 2 - setting alternative start time?
Is it possible to set a alternative start time in DeusExMachina 2?
As I understand it, I must use sunset?
It doesn’t currently, and I’m going to add that to the list of features for the next release.
In the meanwhile, there’s a workaround, if your desired start time is typically after sunset. You can leave DEMII disabled, and use a scene to enable it at the time you want. As long as that time is after sunset, it will start operating as soon as your scene enables it. Have a delayed action on that scene, or a separate scene, to disable it later.
