Deus Ex Machina II -[xxx] : Startup Lua Failed
Hello ,
2 weeks ago I installed this plugin , it seems to work well. But the last couple of days I am getting this error:
And the lights don't switch off anymore.
Anyone has an idea what could be wrong?
I am running the plugin on a vera plus with 1.7.2138
Thanks,
Cor
I had this happen today too. Seems to have started when I deleted a dimmer that I had checked in Deus ex Machina II because I was replacing it with a different model dimmer. I just uninstalled DeM and reinstalled it – it’s not like it takes a lot of time to reenter the options that I originally had.
ahhhhh ha … that could be it yes , i inserted also some new devices.
Let’s try again.
Thanks,
Cor
I’ve got a newer version of DEMII in the works that will be much more defensive about things like that. In the meanwhile, it should be sufficient just to go into DEMII’s configuration screen, and make any change to your selected devices (select something, then deselect it). That will cause it to rebuild the device list and drop any devices that you may have deleted from your Z-wave network.
@ Rigpapa: Oh cool , will it be also whee you can select more with the individual timing of a light . one light goes on for max this tie , another for max that time etc?
I got it running with removing and installing it again. If it hapends again I will try it the other way.
Thanks,
Cor
