I purchased my VERA 1 in May 2009. I have installed Schlage Lock, Trane Tstat, and several on/off switches at our second home. I run the system remotely through Findvera.com. To adjust the set points on the Tstat I have to convert to a factor of (desired temp x 1.8 + 32) which fools the system calc to send a celcius command to the Farhenheit temp setting. Backwards, but it works. I have been reading in the forum that this issue was fixed, but my system and UIx must be dated. Two questions:
I am assuming you are running on UI2: To find the current version you are running, go to setup, then Advanced, then Downloads. You should see the version you are currently at. You will also see the box in which to enter the download URL for a new vesion.
To upgrade, you can find instructions in the Vera Wiki. You will need to search around depending on what release you are currently at, and what you want to upgrade to. http://wiki.micasaverde.com/index.php/Special:AllPages
BTW - unless you have a specific reason for upgrading to the UI4, I recommend staying on UI2, like I have. If it ain’t broke, why fix it?
yes upgrades can be done remotely but I recommend against it because if something doesnt go smoothly you may need to unplug and restart unit to get things working again
