Detecting Devices / Monitoring Connections (especially battery devices)
I did a search to see if I could find previous discussions about this, but was unable to find anything, so hopefully this hasn’t been discussed before and I just missed it…
I’m trying to figure out how to a) check the connection to a battery powered device, b) monitor the connection – i.e. get a better sense of how often it can reach the rest of the network, and how often it can’t. I can’t seem to figure out how to do that for a battery device. For a wall powered/“always on” device I can manually poll it and MCV will tell me if it is unable to reach the device. But for a battery powered device, unless I wake it up, MCV always says it is unable to reach the device (which is understandable if it is “asleep” and not listening for connections).
I currently have a switch that is in a very inaccessible location, so I can’t just “wake it up” to see how it is doing.
I think a simple solution would be to be able to see any “pings” that come from the sensor that z-wave devices supposedly do from time to time, but I’m not aware of a way to do that in MCV.
Any suggestions? Is there something obvious that I’m not looking at?
Thanks,
—Lawrence
Try the datamine plugin and see if you can log the poll times on the graph datamine comes with. I think battery devices by default are around 3 hours before the wake up again but that can be changed by yourself if you wanted.
Vera records the timestamp when a battery-operated Z-Wave device last woke-up and communicated. This is saved in the device variable LastWakeup.
The ServiceID is urn:micasaverde-com:serviceId:ZWaveDevice1.
You could use PLEG or Lua code to periodically check this against the current time and alert/alarm if it exceeds the normal wake-up time.
