Hi guys,
I have a veralite with a DSC 1864 panel, Kwikset z-wave lock, and WS4989 wireless key. I would like to set up a scene which will detect when the alarm is disarmed via the wireless key only (not from any other means) and unlock the Kwikset lock. Similarly, I’d like to detect when the panel is armed via the wireless key and lock the Kwikset lock. Basically, I’d like to use the wireless key for entry/exit to the house.
I found vendor codes 701 (Special Closing) and 751 (Special Opening) in the IT100 developer manual, but I have an EVL-3 so I’m not sure if the vendor codes come across with this combination. Edit: Forgot to mention, I did try to set up a simple notification to see if the vendor codes would be recognized and the notifications did not work (my other notifications work fine).
Anyone have thoughts on how I can make this work?
Thanks,
John
