Demopad
Hi, I’m still getting used to my new veralite and so far I’ve managed to set up a RFx transceiver to control lightwaverf kit (with grateful help from the forum), until I can afford to buy some z-wave goodies ;D
I’ve also posted this in the Demopad forum and hopefully I can get some help here too. I’m trying to find a way to send http commands to veralite without having to using the full expression, ie
http://ipaddress:3480/data_request?id=action&DeviceNum=9&serviceId=urn:upnp-org:serviceId:Dimming1&action=SetLoadLevelTarget&newLoadlevelTarget=80
I have been testing using Hercules on TCP client with vera local ip address and port 3480 sending things like;
GET /data_request?id=status&output_format=xml&DeviceNum=129 HTTP/1.0\x0D\x0A
but this returns;
HTTP/1.1 400 Bad Request{0D}{0A}Content-Type: text/plain{0D}{0A}Content-Length: 104{0D}{0A}Connection: close{0D}{0A}{0D}{0A}Error 400: Bad Request{0A}Can not parse request: [GET/data_request?id=status&output_format=xml&DeviceNum=9]
Connection closed
I’ve tried a few variations and looked through the forum and various micasaverde pages, e.g. UI Simple and Luup devices, plugins, devices and requests and upnp files without luck so any suggestions would be most welcomed :slight_smile:
