I’ve installed and added two Danfoss Living Connect thermostats. It was quite some work to get them up and running, but it seems I finally did. In the process though, I ended up with three extra devices called “_Thermostat” ???. I suspect these are earlier “links” to the thermostats that are no longer used because I had to reset the Danfosses a couple of times.
So I deleted the devices using http://:3480/data_request?id=device&action=delete&device=, since I read this is more reliable than just pushing the waste bucket.
But the second I delete them, they pop back up, with new id’s >:(. Anyone got an idea how to get rid of them?
Since these are technically zwave devices, did you try and exclude from the thermostat with Vera to see if it removes the other devices?
- Garrett
Thanks. Not exactly sure what you mean by “exclude from” though. But I did a heal z-wave network and then deleted them the normal way. They’re gone now …
