I have deleted 2 scenes and rebooted Vera3
low and behold… the scene is gone from the UI but the action still occurs
IE: back door open, turns on flood for 6 min deleted it… gone from ui … open back door… flood comes on…
Hair pulling out
Hair pulling out
try using firefox browser, I have had this same problem using IE
I use Chrome… the scene shows deleted… but still runs…
You saved after deleting scenes right? What make/model of sensor and switch?
It’s possible the are directly associated. Unplgu Vera and open the door. Does it still happen?
If so, click the wrench for the sensor, device options tab…anything listed under associations?
