Delete devices in version 1.0 ?
I use version 1.0 of this plugin and it works great. I have several 433 Mhz devices connected to my two Vera3’s this way. But I also have many devices that are not mine (of neighbours or wrongly created by the plugin). I want to delete these.
I have read that there is a “Delete selected devices & prevent automatic creation”-option under “Managed devices”?
But I cannot find this…
Who can help me ?
You just need to select the device you want to get rid of on the “Managed Devices” tab and press the button “Delete selected devices & prevent recreation”.
I don’t see that button on both my Vera’s… On one Vera I have version 1.0 of the USB RFXtrx plugin, on the other one version pre 1.0
@Korttoma, which version do you have?
I’m on 1.0 of the USB RFXtrx plugin but I am also on UI5 so if you are using UI7 I do not know how it works.
I’m also still on UI5 on both my Vera’s.
I just use the scroll bar to go to the bottom of the managed devices tab and there it is.
Sorry but I don’t see those buttons…
I see “command” and then “RUN” button at the bottom and can’t scroll further down…
Anyone an idea how I can get these delete buttons?
In case someone is still looking for this answer:
Device deletion option is not within the control panel of the target device, but is actually within the control panel of the RFXtrx controller.
