I need some help scripting a scene to control the water system at my vacation home. I have designed/ installed a powered valve system that drains back the water to an external well pit, for freeze protection.
I have 4 devices which I would like to operate in one scene.
Devices
Insteon Outlet - (Powers 2 - I/O Links, 1 power supply and 2 ELK-924 for polarity reversing for ball valves)
I/O link Main (Water Main valve)
I/O link Drain (Water Drain valve)
Insteon Outlet - Water Pump
This is how I would like it to operate.
Insteon outlet on →
30 Second delay (provide time for I/O links to power up)–>
I/O link - water drain On (Closes Drain valve)–>
30 Second delay (provide time for the water main ball valve to actuate before next operation)–>
I/O link - Water main On (Opens Main)–>
Delay 30 seconds–> (time to complete operation)
Insteon Outlet OFF (lock out the I/O’s from accidental change/ power failure or surges.) →
Insteon outlet - Water Pump - ON
Thanks,
R.J.
