So I’m using PLEG with the setting Trigger of if my phone is AWAY arm my alarm. I’m doing this because for some reason the DISTANCE Above/Below trigger is not working.
Then I may do similar when PRESENT to disarm. Question is, what is the distance definition for AWAY and PRESENT
[quote=“nutshellml, post:1, topic:192069”]So I’m using PLEG with the setting Trigger of if my phone is AWAY arm my alarm. I’m doing this because for some reason the DISTANCE Above/Below trigger is not working.
Then I may do similar when PRESENT to disarm. Question is, what is the distance definition for AWAY and PRESENT[/quote]
the answer is documented in the “read me first” message. cf variable Range
