default status to on
It seems with a lot of zwave devices, if something goes wrong, they will default to the last status. Example, light fixture device is off and freezes or or vera breaks. if you use the breaker, it won’t do anything since the last state was off. if it was on when something happened, at least you would have control with the breaker.
I am wondering if there is a way to make devices default to on if something goes wrong?
I think that would have to be a feature of the specific device (e.g. through a configuration parameter).
