My Vera Lite died. MCV support could not revive it.
I’ve ordered the Vera Edge. Since my Lite died, I did not have time to de-register all my devices. Can I use the new Vera Edge to remove and then re-add all my devices?
Hi there,
Yes of course, previously paired z-wave devices on another gateway can be unpaired using the new edge. Just put the new Vera in exclude by pressing and holding down, for 5 seconds, the Sync button on the side. Then do the pairing sequence on each z-wave device, around the house. You should see the Z-wave light on the Edge, fluttering very fast for a second, as a confirmation, after you unpair a z-wave device. If you don’t see the fluttering, the devices might be too far away and it’s not picking it. Try it again, with Vera closer to that device.
