If I set up a scenec using altui on vera the scene overview show the time its next going to run - and it does ok. If I set up the same scene in openLuup for multiple days it doesnt work :-[ and the scene ‘device’ doesnt show the time - see attached
it looks like the scenes work if limited to one day but as soon as I add more days they just dont fire. After editting the scene the log file shows this
This was a problem on earlier versions. I suggest you update to the latest development version by typing development into the Update box on the Plugins page next to openLuup and then clicking on the Update button.
Thank - you that worked fine - I spent ages testing this because I only seem to post about issues - really appreciate the work you have done/do on this
I’m sorry you spent time on a solved issue. This one has been around for a while and was sorted only recently.
Always worth checking the openLuup Versions thread here: http://forum.micasaverde.com/index.php/topic,34526.msg300249.html#msg300249 for changes to the development branch (or master.) For trying out new fixes there is also a testing branch, but I tend not to document the changes there until they make it into development (which is really a sort of Beta test.)
[quote=“akbooer, post:4, topic:194624”]…well, that’s what makes things better.
I’m sorry you spent time on a solved issue.[/quote]
Dont be - trying things is the way I learn about it - until I break it :o
Yes started to keep an eye on lots of posts here problem is I dont always recognise the implication of the words in this case I guess you mean this bit
scenes - day-of-week and day-of-month timing error fixed, and status updates
which is pretty straightforward but at the time I read it I was working on something else - just started clearing scenes off of the Veraedge
