Date stuck in 1970s
Hello,
I’m hoping that someone here can please point me in the right direction.
I’ve been searching around these forums for some time now but can’t find an answer.
The problem is when I first log into mios.com the date and time are spot-on but just for a second or two, and then it immediately reverts back to Feb 1970.
Obviously I have set something incorrectly.
Anybody help?
Thank you.
http://wiki.micasaverde.com/index.php/Install_NTP
Hi Housbot, thank you for the link.
Unfortunately it won’t install.
root@MiOS_xxxxxxxx:~# opkg update
Downloading http://download.mios.com/firmware/openwrt/ramips/packages/Packages.g z.
Inflating http://download.mios.com/firmware/openwrt/ramips/packages/Packages.gz.
Updated list of available packages in /var/opkg-lists/snapshots.
root@MiOS_xxxxxxxx:~# opkg install ntpd
Unknown package ‘ntpd’.
Collected errors:
  • opkg_install_cmd: Cannot install package ntpd.
Any ideas?
Thanks.
On Vera 3 and Vera Lite it looks like only ntpclient is available.
http://forum.micasaverde.com/index.php/topic,9980.msg69088.html#msg69088
Hello futzle,
Thank you for the link.
I ran the command and problem solved, time and date are now spot on.
Thanks again.
