DataYours/EventWatcher Data Warehouse to Azure SQL Server for Data Mining
I wanted a method to store my home automation history for future analyses in developing patterns.
Much to my delight, @akbooer made the awesome solution (which is also an in progress replacement to DataMine) called DataYours.
http://forum.micasaverde.com/index.php/topic,23109.msg157687.html
He also developed a simple logging app EventWatcher:
http://forum.micasaverde.com/index.php/topic,16984.0.html
This project extends the the EventWatcher and DataWatcher data collectors and store that data in the cloud. It does that by using the EventWatcher/DataWatcher Syslog feature to take the single string of data and and parse it into a structured SQL table that will be easy to analyze historical data trends using tools like MS Excel. This allows me to store an unlimited amount of data, off the Vera, for large term data mining trends. I get about 1,500 to 2,500 data points an hour which is about 5MB a day in SQL uncompressed database size.
Technically, it works by taking any Syslog server that can store the data in a backend SQL database, in my case, it’s stored in the SysLogD table and the MsgText column…and parsing the single string it to the structured data table layouts shown below:
Table EventWatcher
Syslog: Mar 11 18:31:45 Vera-30010199 EventWatcher: K [046] Thermostat, CurrentTemperature = 70
To Columns:
  • HA Unit (new colum): Vera-30010199
  • DeviceId: 46
  • DeviceName: Thermostat
  • Variable: CurrentTemperature
  • Value: 70
  • Class: K
  • Category: Table Lookup match EventWatcher.Class to CategoryKey.Class
  • Room: Table Lookup match EventWatcher.Class to DeviceKey.CategoryKey
Table DataWatcher
Syslog: Mar 13 13:30:14 Vera-30010199 DataWatcher: Vera-30010099.449.urn:micasaverde-com:serviceId:EnergyMetering1.Watts 65 1394742614
To Columns:
  • HA Unit (new colum): Vera-30010099
  • DeviceID: 449
  • ServiceURL (new colum): micasaverde-com
  • ServiceType (new colum): EnergyMetering1
  • Variable: Watts
  • Value: 65
  • Device Name: Table Lookup match DataWatcher.DeviceID to DeviceKey.Device Name
  • Device Type: Table Lookup match DataWatcher.DeviceID to DeviceKey.Device Name
  • Room: Lookup match DataWatcher.DeviceID to DeviceKey.Room
Table Device Lookup
  • DeviceID
  • Parent - %Create but Ignore
  • Device Name
  • Room
  • Battery - %Create but Ignore
  • Device Type
  • Alt ID - %Create but Ignore
Table CategoryKey Lookup
  • Class: K
  • Device Type: TemperatureSensor
To do this, I has a copy of Kiwi SysLog Enterprise ($295) which allows logging to a SQL database that we use at work this is the major downside of this solution. If anyone knows a free Syslog server that can log to SQL, please do share. My original goal was to write a small Azure web service to accept the Alternate Event Server HTTPS request and parse it directly in to Azure SQL. Since I had this a Syslog to SQL server, I chose the path of least resistance.
Key Steps:
Important, you must get DataWatcher or Eventwatcher configured first, and ensure the data is SysLog’d.
  • Event Watcher is available in the Vera App Store
  • DataYours includes many other pieces other than the 2 datawatcher files, however are files are focused on storing data locally in databases on the Vera (of limited size and resources). DataWatcher can be installed by downloading 2 data files from the DataYours project:
    http://forum.micasaverde.com/index.php/topic,23109.msg164196.html#msg164196
Steps once you have DataWatcher or EventWatchers installed and Syslog’ing:
  1. Sign up for an Azure Web Database trial. A small database will run $5/mo
    http://www.windowsazure.com/en-us/pricing/details/sql-database/#web-and-business
  2. Create a SQL database on Azure. Note the data you enter for the Database name, username, and password. You’ll also need the IP address of SQL server which will get displayed in the Azure dashboard after your database gets created in about a minute.
Note - Make sure you add your home’s public IP to the access/firewall rules of the Azure SQL Instance. There is a “add this PC” button which makes it simple, Azure will figure out your home’s public IP for you and create the firewall rule.
  1. On your Windows PC (which I also use a the TTS Engine, HTPC, and Camera Server) at home, install Kiwi Log Server (or any tool that can take a Syslog string and dump it to a SQL database.
  2. Run the SQL Query below (using Web based SQL Manager from the “Manage Button” of the Azure SQL instance) to create the database table ‘SysLogD’ (used to store your syslog messages), as well as the key lookup tables Device and CategoryKey.
-- Core objects
IF NOT EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[Syslogd]') AND type in (N'U'))
BEGIN
       CREATE TABLE dbo.Syslogd (MsgDate VARCHAR(10),
                                 MsgTime VARCHAR(8),
                                 MsgText VARCHAR(1024)
       CREATE CLUSTERED INDEX Syslogd_Index ON Syslogd (MsgDate)
END
GO
IF  EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[SplitMessage]') AND type in (N'FN', N'IF', N'TF', N'FS', N'FT'))
DROP FUNCTION dbo.SplitMessage
GO
CREATE FUNCTION dbo.SplitMessage ( @MessageToSplit VARCHAR(MAX), @Delimiter varchar(1))
RETURNS
 @ReturnList TABLE (OrderNum INT, [Name] [nvarchar] (500))
AS
BEGIN
 DECLARE @name NVARCHAR(255)
 DECLARE @pos INT
 DECLARE @OrderNum INT = 1
 WHILE CHARINDEX(@Delimiter, @MessageToSplit) > 0
 BEGIN
  SELECT @pos  = CHARINDEX(@Delimiter, @MessageToSplit)
  SELECT @name = SUBSTRING(@MessageToSplit, 1, @pos-1)
  INSERT INTO @returnList
  SELECT @OrderNum, @name
  SELECT @MessageToSplit = SUBSTRING(@MessageToSplit, @pos+1, LEN(@MessageToSplit)-@pos)
  SELECT @OrderNum = @OrderNum + 1
 END
 SELECT @OrderNum, @MessageToSplit
 RETURN
END
GO
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
IF NOT EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[Device]') AND type in (N'U'))
BEGIN
	CREATE TABLE [dbo].[Device](
		[DeviceId] [int] NOT NULL,
		[Parent] [int] NULL,
		[DeviceName] [nvarchar](255) NULL,
		[Room] [nvarchar](255) NULL,
		[BatteryPercentage] [float] NULL,
		[DeviceType] [nvarchar](255) NULL,
		[AltId] [INT] NULL
	) ON [PRIMARY]
	CREATE CLUSTERED INDEX Device_Index ON dbo.Device (DeviceId)
END
GO
IF NOT EXISTS (SELECT * FROM Device)
BEGIN
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (1, 0, N'ZWave', NULL, NULL, N'ZWaveNetwork', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (2, 1, N'_Scene Controller', NULL, NULL, N'SceneController', 1)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (5, 0, N'Philips Hue Controller', N'X - Media Rack', NULL, N'HueController', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (6, 5, N'LR - TV LightStrip', N'US - Living Room - LR', NULL, N'DimmableLight', 19)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (38, 5, N'DBR - Top Lamp', N'DS - Bedroom - DBR', NULL, N'DimmableLight', 12)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (39, 5, N'DBR - Top Lamp Hue', N'DS - Bedroom - DBR', NULL, N'HueLamp', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (40, 5, N'ENT - Front Porch Light', N'US - Front Entry - ENT', NULL, N'DimmableLight', 11)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (41, 5, N'ENT - Front Porch Light Hue', N'US - Front Entry - ENT', NULL, N'HueLamp', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (42, 5, N'KIT - Pendant Light', N'US - Kitchen - KIT', NULL, N'DimmableLight', 10)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (43, 5, N'KIT - Pendant Hue', N'US - Kitchen - KIT', NULL, N'HueLamp', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (44, 0, N'Nest', N'X - Media Rack', NULL, N'Nest', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (45, 44, N'Activated - Away Mode', NULL, NULL, N'NestStructure', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (46, 44, N'Thermostat', NULL, N'100', NULL, NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (47, 44, N'Inside Humidity', NULL, NULL, N'NestHumidistat', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (48, 0, N'MiOS Update Utility', NULL, NULL, N'MiosUpdater', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (49, 0, N'Russound RNET Controller', N'X - Media Rack', NULL, N'RNETController', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (50, 0, N'Sprinkler', N'Backyard - BY', NULL, N'OpenSprinkler', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (51, 49, N'UPA - Audio', N'US - Patio - UPA', NULL, N'RNETZone', 1)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (52, 49, N'MBR - Audio', N'DS -Master Bedroom - MBR', NULL, N'RNETZone', 2)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (53, 50, N'Sprinkler Front(01)', N'Backyard - BY', NULL, N'BinarySprinkler', 1)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (54, 50, N'Sprinkler Back(02)', N'Backyard - BY', NULL, N'BinarySprinkler', 2)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (57, 0, N'Outside Weather', N'Backyard - BY', NULL, N'weather', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (58, 57, N'Outside Temperature', N'Backyard - BY', NULL, N'TemperatureSensor', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (59, 57, N'Outside Low Temp', N'Backyard - BY', NULL, N'TemperatureSensor', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (60, 57, N'Outside High Temp', N'Backyard - BY', NULL, N'TemperatureSensor', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (61, 57, N'Outside Humidity', N'Backyard - BY', NULL, N'HumiditySensor', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (63, 0, N'GRG - Overhead Door', N'US - Garage - GRG', NULL, N'DoorLock', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (64, 49, N'KIT - Audio', N'US - Kitchen - KIT', NULL, N'RNETZone', 3)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (65, 49, N'MBA - Audio', N'DS - Master Bath - MBA', NULL, N'RNETZone', 4)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (66, 49, N'DPA - Audio', N'DS - Patio - DPA', NULL, N'RNETZone', 5)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (67, 49, N'LR - Audio', N'US - Living Room - LR', NULL, N'RNETZone', 6)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (68, 50, N'Sprinkler Mulch(03)', N'Backyard - BY', NULL, N'BinarySprinkler', 3)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (69, 0, N'GC100', N'X - Media Rack', NULL, N'MultiIO', NULL)
INSERT [dbo].[Device] ([DeviceId], [Parent], [DeviceName], [Room], [BatteryPercentage], [DeviceType], [AltId]) VALUES (70, 69, N'GC100 I/R Port', N'X - Media Rack', NULL, N'IrTransmitter', 1)
END
GO
SET ANSI_NULLS ON
GO
GO
IF NOT EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[CategoryKey]') AND type in (N'U'))
BEGIN
	CREATE TABLE [dbo].[CategoryKey](
		[Class] VARCHAR(20) NOT NULL,
		[Category] [nvarchar](255) NOT NULL
	) ON [PRIMARY]
	CREATE CLUSTERED INDEX CategoryKey_Index ON dbo.CategoryKey (Class)
END
GO
IF NOT EXISTS(SELECT * FROM CategoryKey)
BEGIN
	INSERT dbo.CategoryKey (Class, Category) VALUES ('X', 'Light Switch')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('S', 'Sensor')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('K', 'HVAC')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('C', 'Camera')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('D', 'Door Lock')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('W', 'Window Covering')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('R', 'Remote Control')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('I', 'Infrared')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('O', 'Generic IO')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('G', 'Generic Sensor')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('H', 'Humidity')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('T', 'Temperature')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('L', 'Light Level')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('M', 'Energy')
	INSERT dbo.CategoryKey (Class, Category) VALUES ('Y', 'Scene Controller')
END
GO
  1. Edit the default Kiwi log rules and add an ‘Action’ of ‘Log to database’. , database name, username, and password. It defaults to ‘display’ and ‘log to file’ actions. Personally, I deleted the “log to file” option so I wouldn’t fill up the disk.
    • Run this query below to create the EventWatcher and DataWatcher tables, as well as the SQL Stored Procedure to parse the incoming data any time a record is updated on the SysLogD table. If you update your device table or device data table above (like change a display name or room the device is assigned), you can also re-run this command to reparse all master Syslog data.
    • Use Microsoft Excel > External Data and connect to your SQL Database. Now you can use Excel to filter, chart, and view the data from your home.
PS - Screenshots of data attached of difference of data before and after the stored procedure used to parse the single syslog message text.
Rsyslog is free and logs to MySQL.
I have an older version of it running on my NAS, (but not yet to a database)
Code for EventWatcher/DataWatcher stored procedure and tables from step #6 above:
-- STEP 1: Check if table already exist
BEGIN
                                                MsgTime VARCHAR(8),
                                                MsgText VARCHAR(1024))
END
GO
IF  EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[EventWatcher]') AND type in (N'U'))
DROP TABLE dbo.EventWatcher
GO
	CREATE TABLE dbo.EventWatcher
		Id int not null identity(1,1),
		HAUnit VARCHAR(100),
		DeviceId int,
		DeviceName varchar(100),
		Variable varchar(100),
		Value varchar(100),
		Class varchar(100),
		Category varchar(100),
		Room varchar(100)
	CREATE CLUSTERED INDEX EventWatcher_Index ON dbo.EventWatcher (Id)
GO
IF EXISTS (SELECT * FROM sys.objects WHERE object_id = OBJECT_ID(N'[dbo].[DataWatcher]') AND type in (N'U'))
DROP TABLE dbo.DataWatcher
GO
	CREATE TABLE dbo.DataWatcher
		DeviceId int,
		ServiceUrl varchar(100),
		ServiceType varchar(100),
		Value varchar(100),
		DeviceType varchar(100),
		Room varchar(100)
CREATE CLUSTERED INDEX DataWatcher_Index ON dbo.DataWatcher (Id)
GO
-- STEP 2: Create Trigger, delete obsolete objects
IF OBJECT_ID ('dbo.IO_Trig_DataEvent_Insert','TR') IS NOT NULL
   DROP TRIGGER dbo.IO_Trig_DataEvent_Insert
GO
IF OBJECT_ID ('dbo.IO_Trig_EventWatcher_Insert','TR') IS NOT NULL
   DROP TRIGGER dbo.IO_Trig_EventWatcher_Insert
GO
IF OBJECT_ID ('dbo.IO_Trig_DataWatcher_Insert','TR') IS NOT NULL
   DROP TRIGGER dbo.IO_Trig_DataWatcher_Insert
GO
IF OBJECT_ID ('dbo.IO_Trig_Syslogd_Insert','TR') IS NOT NULL
   DROP TRIGGER dbo.IO_Trig_Syslogd_Insert
GO
CREATE TRIGGER dbo.IO_Trig_Syslogd_Insert
	ON dbo.Syslogd
AFTER INSERT, UPDATE
AS
SET NOCOUNT ON
Declare @MsgText varchar(1024),
		@HAUnit VARCHAR(100),
		@DeviceId int,
		@Variable varchar(100),
		@Value varchar(100),
		@DeviceName varchar(100),
		@DeviceType varchar(100),
		@Class varchar(100),
		@Category varchar(100),
		@Room varchar(100),
		@ServiceUrl varchar(100),
		@ServiceType varchar(100),
		@TempValue varchar(100)
Select @MsgText = MsgText
FROM Inserted i
IF (ISNULL(@MsgText,'') Like '%EventWatcher%')
BEGIN
	IF (@MsgText LIKE '%[%'
		AND  @MsgText LIKE '%]%'
		AND @MsgText LIKE '%,%'
		AND @MsgText LIKE '%=%')
	BEGIN
		SELECT  @HAUnit = (SELECT Name from dbo.SplitMessage(@MsgText, ' ') WHERE OrderNum = 4)
		SELECT @TempValue = (SELECT Name from dbo.SplitMessage(@MsgText, ' ') WHERE OrderNum = 6)
		SELECT @Class =  substring(@MsgText,charindex('EventWatcher:', @MsgText) + Len('EventWatcher:') + 1, 1)
		SELECT @DeviceId = RTRIM(LTRIM(substring(@MsgText,charindex('[', @MsgText) + 1, (charindex(']', @MsgText) - charindex('[', @MsgText)-1))))
		SELECT @DeviceName = RTRIM(LTRIM(substring(@MsgText,charindex(']', @MsgText) + 1, (charindex(',', @MsgText) - charindex(']', @MsgText)-1))))
		SELECT @Variable = RTRIM(LTRIM(substring(@MsgText,charindex(',', @MsgText) + 1, (charindex('=', @MsgText) - charindex(',', @MsgText)-1))))
		SELECT @Value = CASE WHEN charindex(' ', RTRIM(LTRIM(substring(@MsgText,charindex('=', @MsgText) + 1, len(@MsgText))))) > 0
							THEN  RTRIM(LTRIM(LEFT(substring(@MsgText,charindex('=', @MsgText) + 2, len(@MsgText)), charindex(' ', substring(@MsgText,charindex('=', @MsgText) + 2, len(@MsgText))))))
						ELSE RTRIM(LTRIM(substring(@MsgText,charindex('=', @MsgText) + 1, len(@MsgText))))
				END
		SELECT	@DeviceType = DeviceType,
				@Room = Room
			FROM dbo.Device
			WHERE DeviceID = @DeviceID
		SELECT @Category = Category
		FROM dbo.CategoryKey
		where Class = @Class
		INSERT EventWatcher (HAUnit,
							DeviceId,
							DeviceName,
							Variable,
							Value,
							Class,
							Category,
							Room)
		VALUES (@HAUnit,
				@DeviceID,
				@DeviceName,
				@Variable,
				@Value,
				@Class,
				@Category,
				@Room)
	END
END
ELSE BEGIN
	SELECT	@DeviceID  = (SELECT Name FROM dbo.SplitMessage(@TempValue, '.') WHERE OrderNum = 2)
	SELECT @TempValue = substring(@MsgText,charindex('DataWatcher:', @MsgText) + Len('DataWatcher:') + 1, LEN(@MsgText) - charindex('DataWatcher:', @MsgText))
	SELECT	@ServiceUrl  = (SELECT Name FROM dbo.SplitMessage(@TempValue, ':') WHERE OrderNum = 2)
	SELECT	@TempValue  = (SELECT Name FROM dbo.SplitMessage(@TempValue, ':') WHERE OrderNum = 4)
	SELECT	@ServiceType  = (SELECT Name FROM dbo.SplitMessage(@TempValue, '.') WHERE OrderNum = 1)
	SELECT @TempValue = (SELECT Name FROM dbo.SplitMessage(@TempValue, '.') WHERE OrderNum = 2)
	SELECT	@Variable  = (SELECT Name FROM dbo.SplitMessage(@TempValue, ' ') WHERE OrderNum = 1)
	SELECT  @Value = (SELECT Name from dbo.SplitMessage(@MsgText, ' ') WHERE OrderNum = 7)
	SELECT @DeviceName = DeviceName,
			@Room = Room
		FROM dbo.Device
		   INSERT DataWatcher(HAUnit,
						DeviceId,
						DeviceName,
						DeviceType,
						ServiceUrl,
						ServiceType,
						Variable,
						Value,
						Room)
			VALUES (@HAUnit,
					@DeviceID,
					@DeviceName,
					@DeviceType,
					@ServiceUrl ,
					@ServiceType,
					@Variable,
					@Value,
					@Room )
END
SET NOCOUNT OFF
GO
-- STEP 3: Parse existing data
Declare @existingData TABLE (MsgText varchar(1024), Processed bit DEFAULT(0))
INSERT @existingData (MsgText)
SELECT MsgText
from Syslogd
DECLARE @Msg varchar(1024)
WHILE EXISTS(SELECT 1 FROM @existingData WHERE Processed = 0)
BEGIN
	SELECT TOP 1 @Msg = MsgText
	FROM @existingData
	WHERE Processed = 0
	print 'Processing: ' + @Msg
	Update Syslogd
		Set MsgText = MsgText
	WHERE MsgText = @Msg
	UPDATE @existingData
	Set processed = 1
END
-- STEP 4: Usage
-- Create Sample data for testing purpose
INSERT Syslogd (MsgDate, MsgTime, MsgText)
VALUES ('03-11-2014', '18:31:44','Mar 11 18:31:46 Vera-30010408 EventWatcher: K [046] Thermostat, CurrentTemperature = 70')
VALUES (  '03-11-2014', '18:31:35','Mar 11 18:31:36 Vera-30010408 EventWatcher: M [477] Home Energy Monitor Clamp 1, Watts = 916')
VALUES (  '03-11-2014', '18:31:05', 'Mar 11 18:31:06 Vera-30010408 EventWatcher: M [477] Home Energy Monitor Clamp 1, KWH = 65.1870')
VALUES (  '03-13-2014', '18:31:05', 'Mar 13 17:31:18 Vera-30010408 EventWatcher: M [477] Home Energy Monitor Clamp 1, KWH = 85.0010 ()')
select * from EventWatcher
VALUES ('03-11-2014', '18:31:44','Mar 13 20:52:02 Vera-30010408 Syslogd: Vera-30010408.449.urn:micasaverde-com:serviceId:EnergyMetering1.Watts 71 1394769122')
VALUES (  '03-11-2014', '18:31:35','Mar 13 20:51:59 Vera-30010408 Syslogd: Vera-30010408.477.urn:micasaverde-com:serviceId:EnergyMetering1.Watts 926 1394769119')
VALUES (  '03-11-2014', '18:31:05', 'Mar 13 20:51:50 Vera-30010408 Syslogd: Vera-30010408.349.urn:micasaverde-com:serviceId:LightSensor1.CurrentLevel 9 1394769110')
VALUES ('03-11-2014', '18:31:44','Mar 13 20:50:54 Vera-30010408 Syslogd: Vera-30010408.265.urn:upnp-org:serviceId:Dimming1.LoadLevelStatus 0 1394769054')
VALUES (  '03-11-2014', '18:31:35','Mar 13 20:04:44 Vera-30010408 Syslogd: Vera-30010408.304.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated 2 1394766284')
VALUES (  '03-13-2014', '18:31:05', 'Mar 13 20:04:44 Vera-30010408 Syslogd: Vera-30010408.278.urn:micasaverde-com:serviceId:SecuritySensor1.Tripped 0 1394766284')
Select * from DataWatcher
You have been busy… nice to see that data going to a good home. :slight_smile:
Adding some new components that should be ready soon:
  • Multi Device Support - Device table now supports multiple HAUnits
  • Health Monitoring - Keep the Device table updated with the latest date or battrey level anytime a new value is created in Datawatcher on a per device basis.
    1. BatteryLevel (integer)
    2. Last date LastCommFailure value updated
    3. Last date LastPollNoReply value updated
    4. Last date LastPollOKUpdate value updated
  • Error Table - Any data that can’t be parsed by to EventWatcher or DataWatcher gets copied to this table.
Can you expand on that? What sort of things are you seeing here?
ie. my fault, or yours :wink:
Not your fault, this is when we can’t parse the syslog text.
There is no delimiter, so the parsing engine is getting a little complex when spaces are in the variable value…and sometimes a line is skipped.
Yes, the format is terrible… the whole point of EventWatcher in the first place, and then syslog, though, was to make the logs easy for people to read, not machines. I could add a JSON option.
I would eventually like to move to a web service where the alternative event server. That way no parsing will be required (or the Syslog server middlman).
Do you think your DataWatcher front end could be used to build the devices to watch?
Otherwise, I guess I can maintain in in code re:
http://forum.micasaverde.com/index.php/topic,16713.msg153469.html#msg153469
However, today SQL parsing is easier than web services.
Think I might need a little more in the way of detailed requirements, but if you’re asking whether the existing DataWatcher can direct its output to something which sends an HTTPS request rather than a syslog UDP datagram, then yes. Very easy.
Agile,
Are you still using this? I’m thinking I might be able to convert this to MySQL/MariaDB - thoughts?
No, I embarrassingly went back to DataMine so it would work with my home tablet + Imperihome.
http://forum.micasaverde.com/index.php/topic,22763.msg188456.html#msg188456
I used akbooker’s solution which I am still using today to direct events to an HTTPS listener hosted in Azure. From there I parse the incoming string and insert into a SQL Database for trend analysis and have an Azure Event Stream Service that is watching the incoming data to perform Windowing functions over time to detect when strange things happen. This also allows for directing the stream to Azure ML services for additional machine learning capabilities on the collected data.
I installed everything according to the instructions and had to make a few small tweaks. I modified the LUA script where his is logging to a syslog server. I enabled syslog logging but I replaced that code with a HTTP Rest Call to my endpoint that sends the formatted “e” parameter as a JSON string, you can search by my user name for more details. I will post that code and maybe some examples - just wanted to say this is still possible and I have had ZERO downtime / errors by doing it this way. I have over 112,000 events and it is very fun to dig for trends and outliers in the data. This also allows me to create dashboard in Power BI for viewing on almost any platform, mobile, tablets, etc.
And as far as the cost - I think I am still under $4 a month (I have an MSDN account which gives me some credits so the cost is $0)
