[quote=“akbooer, post:52, topic:186018”][quote=“ServiceXp, post:51, topic:186018”][…] no information for either one of the humidity sensors (they have been changing their % reading through out the day).
How should I go about diagnosing the problem?[/quote]
Your first port of call is always the Configuration page. If you you click on the [tt]Watcher[/tt] icon then the information there should be very revealing: in particular, which variables it thinks are being watched, and a tally of how many times they have been updated. Similarly, the [tt]Cache[/tt] configuration will tell you what has been received and stored.
If you care to share the above, then we can make progress.[/quote]
Thanks akbooer
Here is the Watcher Info:
[code]DataWatcher2 CONFIGURATION at Mon Mar 2 18:53:22 2015
DAEMON = {
VERSION = “2015.02.12 DataDaemon7 @akbooer”,
client = “DataWatcher2”,
destinations = {“127.0.0.1:2003”},
errors = {count = 0},
http = {received = 10},
ip = “192.168.1.5”,
start_time = “Mon Mar 2 07:08:57 2015”,
udp = {
last_received = {},
last_sent = {[“127.0.0.1:2003”] = “Vera-XXXXXXXX.XXX.urn:micasaverde-com:serviceId:EnergyMetering1.Watts 1251 1425340389”},
received = 0,
sent = 427}}
DATAWATCHER = {
VERSION = “2015.02.18 DataWatcher7 @akbooer”,
tally = {
[“028.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel”] = 0,
[“028.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature”] = 15,
[“092.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel”] = 0,
[“092.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature”] = 44,
[“108.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature”] = 227,
[“140.urn:micasaverde-com:serviceId:EnergyMetering1.Watts”] = 141}}
[relay] = {
DESTINATIONS = “127.0.0.1:2003”,
SYSLOG = “”}[/code]
And here is the Cache info:
[code]DataCache2 CONFIGURATION at Mon Mar 2 18:53:42 2015
DAEMON = {
client = “DataCache2”,
destinations = {},
http = {received = 3},
ip = “192.168.1.5”,
start_time = “Mon Mar 2 07:08:55 2015”,
udp = {
last_received = {[“127.0.0.1:2003”] = “Vera-XXXXXXX.XXX.urn:micasaverde-com:serviceId:EnergyMetering1.Watts 1215 1425340409”},
last_sent = {},
received = 429,
sent = 0}}
DATACACHE = {
VERSION = “2015.02.18 DataCache7 @akbooer”,
stats = {
cpu = 2.315,
updates = 429},
tally = {
Vera-XXXXXXXX.028.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature = 15,
Vera-XXXXXXXX.092.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature = 44,
Vera-XXXXXXXX.108.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature = 228,
Vera-XXXXXXXX.140.urn:micasaverde-com:serviceId:EnergyMetering1.Watts = 142},
whisper = “/tmp/log/cmh/datayours/”}
[cache] = {
LOCAL_DATA_DIR = “/tmp/log/cmh/datayours/”,
SYSLOG = “”,
UDP_RECEIVER_PORT = “2003”} [/code]
So If I’m reading this correctly it’s not getting the updates from my humidity sensors?
